I could use a spare evaporator box and amplifier for my '86 FJ60, which has all the systems and wiring from my '89 FJ62 donor vehicle. How about an even trade?So just doing a little more research and found that the evaporator box and amplifier I have are from an FJ62, not a 60. So either I find a box from a 60, or wire in the 62 amplifier to work. The wiring connector I posted was correct for the 60 A/C, the blue and red went to the fuse, the white and black are ground, and the solid black was to the igniter.
You looking to sell or trade a 60 amplifier for a 62 amplifier?![]()
Thanks
Scott
Sounds perfect to me, a trade would be great. If you'd like to message me with your address I'll do the same for you.I could use a spare evaporator box and amplifier for my '86 FJ60, which has all the systems and wiring from my '89 FJ62 donor vehicle. How about an even trade?
That's the exact harness I need, I'll take it. Price? Did you happen to check to see if you happen to have the dash piece?Hi,,
I have the harness and the amplifier for a 60 series,
let me know if your still looking,
I'm converting a non-A/C FJ60 to an A/C version. I have everything except the wiring harness and the carburetor kick-up with associated VSV. Thanks in advance.
Scott
That's the harness I was thinking of. Thanks for the picture. By looking at it I believe my connector that is going into the main harness is different, maybe I don't have the actual plug under the dash, although I checked the fuse panel and the wiring is in place to that panel. Here is a picture of the open connector from the main harness I have.
Thanks
Scott
I need the same harness. Anyone else have one? Or @ToyotaMatt can you build me one?
