FJ55 windshield wiper help needed
Iowa Park. TX
Posted this in the 55 corner also. The wipers stopped working on the pig this weekend. It is a 12/71. I pulled the motor and it seems to be locked up. Should it rotate freely? What wires coming off of the which should have power? What wires going into the motor should get power? Any help is appreciated.
It will not rotate freely. It is gear driven so you're trying to overcome the mechanical advantage that the motor has.
Took apart the motor and it turns freely onece you disengage the worm gear. Brushes all look good. There are 2 wires that go into the worm drive gear compartment that make contact with a round plate inside. What do they do? Anyone have any idea which prongs get power?
I have 2 wiring diagrams for the 55; one is for a 5 5 LG and 5V with tandem master cylindre. The other show for a 55(L) V series. The pig was built 12/71 not 9/72 as earlier stated.
I was able to short across the motor connections and got it to work. Blue/Red is low, and Blue/Black is high. Blak is ground:doh: The other 2 prongs I'm not sure about. There is no power coming from the switch, the fuse is good so maybe the switch is bad? Got to figure out which wire going to the switch is suppossed to have power so that I can check that.
are you sure the ground doesn't run thru the switch?? no expert, but for some reason I thought some 40's were run that way. power went directly to the wiper motor
The wiring diagram shows that the power runs to the washer pump. There is also a wire going to what they have labeled as the computer.
David, the power lead should be solid blue.
