The power path runs from the fuse block to the lighting switch, and then to the running light circuits.
You may have a good fuse, but are you sure you actually have power at the fuse block? Check it with a meter or test light to ground.
From there, check that you have power at the lighting switch. If so, check the output of the lighting switch.
Not far from the lighting switch the circuit will divide for front and rear running lights. It's a pretty safe bet your problem is between the fuse block and this point.
Do you have a manual with a wiring schematic so you can trace this?
