i have this pto on the rear ,on the 3 speed coming from a 1964 firetruck (and i have the F125 engine from the fire truck)There's a provision for another PTO gearbox which is attached to the back of the transfer case input shaft. (the stamped steel cover is removed). The drive shaft out of this box extends to the rear, and I think was used in one application to drive a water pump for a fire truck.
in fact, no , mine had his engine replace long time ago by a F155, and i was in search of a F135, i found one in dubai, but when it arrived, it was a F125 coming from a 1964 firetruck with a 3 speed gearbox , special engine made by toyota for firefighters with big oil pan and hydraulic hoses and and rear pto with hydraulicInteresting a 64 would have a F135. I remember F105 on early 20 series and F120 thn into the early 1960 models.
Will do a pictureWhat was used to power the pump for the hydraulic hoses? Direct off the engine or the rear PTO? How much oil does the engine hold including the filter. The F engines held about double what the V8s held from the same time period. Part of what made the engine idea for desert regions of the world.
