FJ40 wheel cylinders
here and there
I recently bought new rear wheel cylinders from ccot, the stock shoes do not fit into the grooves. Any suggestions?? Besides grinding the shoes to fit
Quickest solution would be get the correct cylinders from Mark's Off Road
or Cruiser Outfitters
Both support this forum, can be reached by phone and will send you the correct parts
@mike1978fj40 Do you have the old ones? The same thing happened to me when I replaced my rear wheel cylinders with aftermarket made in Japan wheel cylinders. I removed the slotted adjustment bolts from my old cylinders and used them. The slots were wider and angled on the old ones and have worked perfectly on the new cylinders.
Pics are from a @wngrog build thread. Stock is on the left:
View attachment 2222735View attachment 2222736
Yes I do, didn’t even think to do that, thank you
Did you use the other oem
Bolts as well? The new ones are much larger than the originals
