Wanted FJ40 Vacuum Switching Valve 74 Cal Spec
Efjayforty
dalton ga
Trying to find an "Evaporative Emission Control Device" for my 74 California Spec FJ40, part number 17650-60020. It looks like the one pic but the one in the pic only has a 3 wire connector and the one I need has a four wire connector. Thank you.
I appreciate it but yours is for a 75 according to the part number and what I need is 17650-60020 for a 74.
I have a box of those…somewhere.🤔
72-74 use the same emissions controller so I would think the VSV from those three years may be interchangeable.
On my 74, the part number for the computer under the dash is different for cal spec than non. Also, the part number for the vacuum valve is also different for cal spec. I have the non cal spec vacuum valve (actually two of them) and they each have a 3 wire connector. Here is a pic of my harness connector that the correct valve would connect to. Thanks, Jess
John,
I will send you a PM. Thanks.
Cimarron,
One of the two that I have I got from YOU! You are welcome to have it back.
