- Location
- United States
I’m looking for a set of chains and brackets for my FJ40 tailgate. I have also seen a few people use cables instead of chains, seems like a cleaner look but a little less authentic. I’m open to suggestions or ideas.
Thanks for the reply gericurl. I was thinking I would be making my own chains if I didn’t get any reasonable responses. I actually found a set of the brackets just after my post so I’m good on brackets. Could you share where you found the chain at?This is not what you want to hear, but good luck on the chains. I do hope you find some.
I gave up although I've seen a few sets trade hands in the 5 years I've been paying attention (not my hands). Some I just wasn't willing to make the $pend.
I might have a set of the brackets (the piece that bolts to the tailgate that the chain attaches to) for sale in a bit. They are in my "thinking about selling" pile. I'll think harder about them.
On the chains... I found some vintage chain that matches and fabricated the ends as close as I can tell from pictures, tool hardened and all. Shhhh don't tell anyone though, they'll revoke my OEM card. LOL.
My buddy that collects old stuff from swap meets. I can grab a pic for you on Friday or Sat.
Gabe , You have any idea where these come from ?@dieselbj42 had new oem fj45 tailgate chains. You might want to check with him.
Casey, like these?Gabe , You have any idea where these come from ?
Thanks ,
Casey
btbprod.com
No the other side where those hook to. They made a special plate that bolts to the ambulance door hinge holes.Casey, like these?
Tail Gate Latch Set for 1958-1984 4x-Series Toyota Land Cruisers - BTB Products - Land Cruiser Restoration and Parts
Tail Gate Latch Set for 1958-1984 FJ40/FJ45 Short Wheel Base Toyota Land Cruisers. This pair of aftermarket latches come Silver Zinc Coated.btbprod.com
Anyone know who makes these ? I don’t want to make a set and I’m aware they aren’t OEM. I need a set for my boys 75 that we put a FST tailgate on.
Here you go. I would buy there and modify a plate.No the other side where those hook to. They made a special plate that bolts to the ambulance door hinge holes.
I have the stock OEM hooks but the hole patter is wider and doesn’t work with 75 and latter 40’s. Someone solved the problem by building that plate and making the hook end.
btbprod.com
Yep this is what we need. The OEM ones don’t fit the tail gate latch bolt pattern. I have multiple sets of the OEM ones.I did not make the set pictured above but I have done these before - need to check with my engineer if they got revised after our first set as I know we had to make some small tweaks to make them function “naturally”
