fj40 rebuild
Just got my first fj40 (1974) Compression front to back is 120,112,105,95,118.114. Did test with cold engine. Squirted oil in # 3 and compression jumped to 130. Rings? Suggestions? Can oversized pistons be bought for the F engine? Sources? Thanks for the help! :)
I would not waste time rebuilding an F unless it is a late F like a '74. You'll end up spending as much for an F as a 2F and a rebuildable 2F core can be had cheap. Yes oversized pistons can be had for either. Why not just run it the way it is until it blows or locks. In the mean time, enjoy the cruiser and look for a rebuildable 2F.
GL
Ed
Duh, I just reread your post and it IS a '74. Same as a 2F only slightly smaller bore. $$$ is the same either way, but the '74 F is a good motor. Pistons are no longer available from Toyota, but you can get a set with rings and wristpins for $300. SOR, CCOT, and a bunch of good vendors here.
Keep the F, they're better for torque and longevity... Everybody is getting a 2F, keep the origional character and integrity. I've got a 74 with an F that will need a rebuild in a couple years, and I'm going to rebuild, not replace. Your choice, but my vote is origional. Good luck!
I believe you should check compression warm.
Yes, it sounds like maybe rings, at least in the #3 cylinder, but things might look better if the engine is warmed up. How do you think it drives? Technically, the cylinders should be within about 14 of one another, so, except for #4, if it is running OK, you may be fine for the time being. I'd redo the check with the engine warm, and wet test all of the cylinders.
Your numbers aren't all that bad...factory says 10 per cent from lowest to highest, you're essentially in there...lots of guys on these boards running around with 100 or less....wheel it till it breaks!
If its running fine, I would also leave it alone. You probably will get a few more years out of it before it becomes a noticable issue. Check it every year when you do plugs and monitor the progress.
Definitely do the compression test hot. Those numbers are possibly meaningless.
Get it warmed up then pull all the plugs. Block the throttle open and crank the engine at least six revolutions per cylinder. If you don't have a screw-in type tester make sure to hold the rubber thingy tight in the sparkplug hole.
After that, if there is still a variance put a few drops of oil in each one before testing. You already know that any rise indicates how much loss of compression is because of rings.
Yes, the 'F' can be rebuilt and Toyota lists FIVE oversizes for rings, pistons, bearings. After you do the five they advise sleeving and starting over. :)
The flywheel in 'F' equipted cruisers is heavier than in 2F vehicles. That's why they feel like more torque. Also why they rev slower.
The 'F' is a good engine. It uses only a modified bypass oil filtration system and that, plus a few more cubic inches displacement is the main change in the 2F.
