FJ40 Radio Question
Made a recent purchase of a 1981 FJ40 but no radio, or antenna, but a hole in the dash for one. Does anyone know what radio or whatever else may have been stock for a 1981 FJ40? I have seen several of the am radios, but mostly in the 70's models. Are these still available through Toyota? Saw a few things on ebay, but again I am not sure what was offered in 1981.
Thanks
for 81 this would be the correct AM radio
this is the speaker , behind glove box
this is the correct antenna in the correct location
there was a AM/FM option as well as a cassete mounted elseware(underdash)
a CB radio was also optional(for all toyotas)
I beleive there was a in dash kit(where radio is) I mounted mine there, but didn't have the kit
8 track was also optional but not sure if still in 81
and no, toyota does not have any old stock of radios, but you can find them on the internet, seem a few new old stock complete kits(radio, speaker, antenna)
CD players will not fit in the stock radio hole, I would advise not cuttin the hole to make a CB fit.....if your 40 is a nice one.
there was also a radio block off plate offered(stock if no radio ordered)
it was just a blank hole with a plug, I put the switch in(bitch to find one the right diameter) to use as a electonic idle up, my carb is a new fj60 carb with the AC idle up, my 40 has no AC, so I am using this for the idle up(like a hand throttle, but can only have one set speed, unless adjusted at carb) its not complete....so I used it for my OEM fog light.....then I found the OEM fog light switch....so back to the elec idle up..........need to get that finished....
Pimp
What is the button located to the right of the cigarette lighter?
I got a decent used AM radio, speaker and mount from Cruiserparts.net.
Radio was 100.00 and in good shape, speaker was new, 50.00 and the mount was used and included with the speaker. OEM for a 79 40.
