I finally started in on my fj, and I had some questions...
1. We found a bunch of rust on the piece of metal between the windshield and the black dash pad. looks like I can weld a patch into the back of it and then seam seal it.... any thoughts?
2. I wanted to try and start the motor, since I have never heard it, and could not get it to fire. I was getting a very weak spark off of the spark plug wires and (using ether) could not get fire.
My question may sound silly, but it has been a while since I played with ignition. I connected the battery positive to the resistor, and the resitor then went to the positive side of the coil, the negative side then went the distributor on the connection on the side (points). I got a spark off the plug wires, however it seamed really weak. Any thoughts what I am not doing? Or what could be wrong?
3. It appears to be a california car, any thoughts on the smog equipment? SHould I just cap off the stuff, or is there I should undo, that voodoo, that california does.... so well.
