SOLD FJ40 - NorCal - Parking Brake/ E-Brake Components ('74-'80 4 spd.)
Livermore, CA
  1. 40 Series
Looking for some components for the parking brake / e-brake assembly for this 1975 4 speed that will be going into my rig (pic attached). Doesn't have to be new or be pretty but do need to be functional and/or serviceable. Need everything after the rear output seal (piece that holds the speedo cable) and before the drive shaft.
Project is (will be) a frankenstein of different years/ parts, if more detail is needed for sourcing please let me know.
Thank you,
Jimmy
Drum, backing plate, internals. Handle and cable too?
Thanks Mark. I believe I have the handle and cable covered. Need everything after the rear output seal (piece that holds the speedo cable) and before the drive shaft. Not sure of exact/ best terminology but...backing plate, drum, internals, any gaskets, any nuts/ bolts?
Pic above is what it looks like right now. Won't be getting installed tomorrow but trying to source missing parts before they are actually needed.
Reach out to Georg this is his handle on here @orangefj45 he owns Valley hybrids in Stockton. If I were you I’d load it up and drop it off at his shop, he has everything to get you going.
Are you going to be using 75-80 driveshafts? Or are you planning to cross-drill the drum for something custom?
Thanks Mark for triggering the thoughts. I was expecting just to begin the searching process with the MUD members for parts, no real "plan" to speak of. Since posting yesterday I am realizing that maybe sharing more detail for the parts I have available ("planned" to use), might be best. I will continue to put the "plan" in quotations since it is a bit of a fluid situation.
*ALL is intended to be "on a budget", as much as one can when working with 50 year old FJ40's
Most Current "Plan":
1967 frame + tub (Used because of title).
??/1975 - 4 speed trans + t-case.
12/1969 Axles - to be used for eventual disc brake swap and get away from ball/ claw.
1967 parking brake handle + cable still in place + seem intact.
'75-80 Drive shafts.
Other Parts Available (May or May not be used:
1965 frame / axles / 3 speed trans. + t-case / drive shafts
1969 frame + tub
1967 axles
I have what you are looking for. I will get you some pics later today.
