Fj40 lean
Lockhart
Looking for some help. Couldn’t find any answers in the FAQ lean section.
my passenger side shock is approximately 1in shorter than the driver side. Brand new bilsteins up front, could the issue be the leaf springs?
Could be a lot of things. Leaf springs, or frame out of whack. Could be an illusion, but this picture looks like the vehicle is lopsided. Take a look at the windshield frame bottom as a reference from left to right.
Not sure, but it kind of looks like your right side shackle is pushed further forward than the left. That indicates a flatter leaf spring.
compare the shackle angles side to side.
Intake it before the shocks this lean was not there?
Do you have shoulders on your shackle bushings? Are the shackles tight against the springs?
What does the rear look like?
Did it always have this lean or had you have it after doing the shocks?
you may be right here. Driver spring is 42” and passenger is pushing 43”.
Considering that the 'classic' cruiser lean is to the left [meaning left spring already has more compression in it] that would make it very likely that your right spring is doubly weak.
If you were to do a free-droop test [no shocks] you would probably see an even greater disparity between the two.
Time for new springs.
That was and educated suggestion. When I brought my Colombian FJ43 into the good ole USA the front bumper was never horizontal to the ground, you know, level. Even after a suspension change and several times on the lift trying to figure it out. It was not the normal LandCriuser lean.
So, I took it to the frame shop and voila. My 43 sat as straight as me on a Sunday morning!
Know this jjh123...... I don’t sass Colombian 43’s..... I drive them!
devo
haha thats right! My mistake. I'll dive in a little deeper and see what's going on. Hows your truck treating you?
Hey Devo! What do your front leaf spring perches look like? Are yours bolted on too?
Perches are riveted on, not welded. More evidence of trauma.
Gives more credence to the theory that your frame might be bent. :-(
Bummer! How does one go about properly attaching the perches? Can any professionals out there rivet this, or do I source the bolts and address any frame alignment issues?
I don’t know the answer? Someone here surely does though.
I would say that if the perch is in the absolute proper position as it was when riveted from the assembly line it wouldn’t matter if was fixed in place by a bolt or a weld. From your photo it looks pretty close, but, that bolt hole could be wallowed out also.
In years past I have broken off spring hangers and perches on the trail and have had them welded back into place and never had a lean afterwords.
Since there is nothing else grotesquely obvious you should have your frame looked at. People relocate there spring perches and hangers all of the time to accommodate longer springs.
Not to sass, but I don’t know where or who you got your 43 from. There have been a few dogs dumped on the market that’s for sure!
If 65swb45 had the time or impetus he could tell you some SA 43 horror stories. There is a thread of horror stories out there somewhere.
So its time for you to drop those questionable springs off of your 43 and do an inspection and some measuring.
All said, I don’t think you have a serious problem, just a PIA!
That is all I got.....
devo
