FJ40 Fluid levels?
tennessee
I am restoring a 78 fj40 , when I started the project I drained all the fluids, can somebody tell me how much axle fluid I need to purchase to fill the stock rear end, front end, transfer case and transmission? I can't find the specs anywhere... Also I imagine that 80-90w is the proper oil for all, correct?
Thank You,
Clint
Welcome.
80W-90 gear oil is what you want to use.
Refill capacities for the drive train:
Front diff- 2.6 quarts
Rear diff- 2.6 quarts
4-speed trans- 3.3 quarts
3- speed trans- 1.8 quarts
Transfer case:
Without PTO- 1.8 quarts
With PTO- 2.2 quarts
Good luck!
-Steve
Colorado Boy-74-FJ40 said:
Go with synthetic
Why?
I can completely understand it for something with very close operating tolerances and extreme heat, ie. gas turbine engines or race engines, but there is nothing on an old Land Cruiser that justifies the added expense.
I do not think that the oil will stay in the compartment long enough to be able to prove any form of benefit over conventional oil. I am not insinuating that synthetic oil will leak past a seal or gasket easier; rather I do not think that you will be getting the bang for the buck when factoring the additional cost of synthetic oil vs. conventional oil. The only thing you can be sure of is that your wallet will be lighter when purchasing synthetic oil compared to conventional oil.
New engine after break in? Perhaps. But not a Land Cruiser six.
:beer:
Poser said:
Welcome.
Transfer case:
Good luck!
-Steve
Dude... is there actually anything you don't know about these things? Incredible.
:cheers:
Scott
Darn you might be on to something there! BeerPal...
Say! What do you want for that part?
Well how about 3 cases of (insert favorite beer here)? You can BeerPal that to...
I spent time in Alaska and grew very fond of synthetic. The guy is restoring his rig and if it were me, I'd go with synthetic. I know he is in Tenn. and probably plays into the picture. But as for myself, I used synthetic. Got a good deal on it at a NAPA 40% off sale. I take my rig hunting in eastern Oregon and Colorado where it will see -35 degrees F . It seems to lag less when it is moving. Personal preference I guess. to each is own.
