FJ40 / FJ 73 diff swap
what year 40?
early had coarse axle shafts
are you changing both front and rear?
ratios the same?
flange pattern may be different
I’m pretty sure they are even the axle shafts front and rear are the same
what year 40?
ratios the same?
1977 FJ40
If both front and rear bolt straight in I will swap to get disc brake front and the hand brake on the rear wheels as i am also swapping to a 5 speed.
I haven't had the diff's apart yet to see what the ratio's are at this stage.
If not I will just strip the brakes etc and bolt them to the existing diffs.
