I have some timing/ignition issues with my -68 FJ40 with Denso distributor(F engine). I find many newer distributor, but not the 60042. It looks identical to a 2F distributor, except the vacuum connection. Will a 2F work, or is it set up differently?
My problem is a timing mark jumping around, backfire, hard start etc. Changed fuel, spark plugs, cables, points, refurbed carb, set valves. I think it might be too much play in the distributor axle, but i’m only guessing.
Grateful for help!!
Grateful for help!!
