Wanted FJ40/BJ42 Power Steering Parts
Status
Not open for further replies.
  1. 40 Series
Looking for late model FJ40/BJ42 Steering Parts. In Canada I think it was only offered on 83/84 models.
I have the Toyota PS box, I have the PS pump mounted to the engine, but need the lines, and column parts (is it an entire steering column???) to connect everything on my truck.
Looking for any guidance or assistance with sourcing the parts to put PS on my truck. Lines I would likely buy new, but the column would love to pick up if someone has the parts lying around.
Thanking Mud Members in advance.
Adam
F or B stuff?
the F cooling line was reproduced and was available
do you have the 2 piece column? you can shorten the lower section easier than finding the correct part
if you have the 1 piece column you can space it out further into the cabin
the hoses, you should only need the pressure hose as the return is just oil rubber hose
the hose will matter which engine it is on F or B
Thanks for the reply.
Great questions on engine, I could go either way since I do have both. Debating 3B since I have a 5spd to go with that and engine mounts and transmission mount, my 2F is only a 4spd and not really interested in changing input shafts on the transmission and dealing with the ebrake, unless someone has an amazing solution for that. Maybe I will be 2F since that will be easiest for the time being. Can modify to 3B later....ultimately it all comes down to what pieces I can gather now.
I do not have the 2 piece column, only ones I have are 1 piece.
Not sure what parts I need to change my 1 piece column to a 2 piece column...anyone have anything out there that will help?
Adam
I have a full US spec late model 40 Power steering setup in NY. It has the two piece column.
It all came out of my 05/1981 FJ40, not sure if you are interested on this as I pulled it out the other day to post here for sale. Just need to take some photos.
These are some old photos while on the 40
Status
