FJ40 1972-1977 Hazard Switch Connector & Terminals Identification
if it's NOT a OEM TOYOTA parts maker YAZAKI or SUMITOMO alternative solution , then the BAR is lowered to a DETROIT level ...
thus making it a Passe' product to incorporate into any 9/72-1977 Land Cruiser FJ40 FJ55
in Vintage Toyota Land Cruiser History in general , when ever a NON-MADE-JAPAN alternative needed parts solution is initially accepted because it's the EAST way out ...
down the Road , it proves inferior and poor choice in the end of the day
case and points :
- WEBBER Carburetors SUCK ...
- headers are problematic and leak at all the gaskets have a short service life compared to a manifolds OEM set up
- who loves there aftermarket ignition system, and will brag about it here ?
- yea right
- poly fuel tanks , leak and are stupid cheap 2nd rate topic
- and the list goes on
Matt, do you stock these contact springs for this connector? I need a full set around 10 total.
They do not exist anywhere in the world anymore. I’ve searched the planet.
is your Terminals parts inquire intended use for the Harness side Connector plug or the device side Switch plug ..........
depending of which one you reply back to here , perhaps a out-side the JIS box might be ....... around :poof:
Matt
Matt
Hey Matt - gotta question for you about my horn relay - please check your inbox!
