Metal pipes are brokenthat is the vacumn switching unit for the transfer case, it will engage the front drive.
what is broken? metal pipe or rubber hose?
How can I verify if it’s been changedYou must have NO 4 wheel drive, OR, someone changed the transfer case to mechanical.
The have changed engin to v8 sbc 283 I wander what else the have changed I have more rust then carYou must have NO 4 wheel drive, OR, someone changed the transfer case to mechanical.
Well I have just got the fj40 it’s in part I am fixing it first I will know when I finish with fixing I am taking care of rust and taking apart all parts it’s been standing for 20 yearsHow do you engage to get into 4 wheel drive ?
I have a stick that goes in or out don’t know if it’s engaging front wheelWell I have just got the fj40 it’s in part I am fixing it first I will know when I finish with fixing I am taking care of rust and taking apart all parts it’s been standing for 20 years
Yes it’s same as photoDoes the stick go into the transfer case ? Is the stick under the dash ? Look at image, does your transfer case have this setup ?
That’s what it look like I have to build new tubing with fitting it’s all rusty and I think it will brack if I try to open like all the rest all braking on first tryIf so, then no vacuum is getting to the transfer case to engage 4 wheel drive, if your tubes are cut. (or broken)
I have a hose going to the engine so I think I only need to change the broken pipes for now and hope for the bestSounds like you have plenty of help figuring out the vacuum switch. What I would be sure of is the vacuum line coming off the intake manifold if capped off. This system is design to create vacuum at the switch but nothing is actually suppose to be flowing into the manifold. Don't need any dirt getting into your valves and cylinders. Also vacuum leaks is generally something to avoid.
n you send some photosYou can also convert the transfer case to manual front drive engagement if you can't get the vacuum system working. That's what I did on my '71 FJ40. At the transfer case it's a pretty simple changeout of just a few parts. And you'd need the shifter, boot, and linkage, plus a hole in the transmission hump. You could probably find the needed Toyota parts used here on MUD.
I can later this morning. In the meantime, here are some diagrams to compare. On the direct type diagram you can see the small rectangular housing that bolts to the side of the transfer front extension housing. On the second vacuum type diagram you can see that the vacuum housing has the same bolt pattern, so all you have to do is unbolt that housing and bolt in the small direct type housing. The rest is all linkage, which you can probably find used.Can you send some photos
