FJ Cruiser Internal Winch Mount
Chesnee, SC
We are proud to introduce a winch mount for those that wish to keep their stock bumper.
The winch mount is built up from our tried and true bumper base that is used for our tube bumper design. The photos show a Viper Elite 12K winch with solenoid bridge mounted. Minor trimming of the center radiator support was required to fit this large winch. Most winches will fit with this design, no separate solenoid box required although they will fit as well.
The winch mount uses the stock plastic bumper cover as shown, owner only needs to cut the front to accommodate the fairlead and 2” receiver. Winch mount will also work with aftermarket skids.
Lower grill left out for access to winch controls.
Introductory price $550.00 plus shipping This item is on sale now. Units are built to order.
Winch mount specs:
Bumper base is ¼” plate attached to the stock front bumper plates (4 bolts) and also to the side of the frame ( 1 bolt). And 1.5” X 2.5” 3/16” wall rectangular tube.
Winch plate is 1/4” plate welded to the main cross member and braced below
2” receiver welded to the bottom of the winch plate and the face of the cross member
1/8” steel bash plate protects the bottom of the radiator.
Weight- 40lbs
