FJ-80 top heavy
the tires are't 2K, about 1200 or so. I am considering beadlocks or those funky wheels Slee might sell that have a DOT legal beadlock when I consider 2K :)
I think they are stock with extensions. Good point. Could beef those up when I move up and offset a lot of the lean.
Thanks.
Depending on what kind of wheeling you plan, there is a balance point between 'lean' and articulation. There is no perfect lift, any setup that maximizes one desireable trait will compromise others. Clearance is traded for a lower COG, flex for stability, power for reliability, a straight body for an easygoing attitude. It's all about balance and what you want to do with your truck.
-Spike
I plan on getting a higher spring rate first, then seeing what I need next. No point in pulling the trigger on everything all at once :)
Yep, all depends on the situation, skills, spring rate and etc... You can be top heavy but at the same time you can avoid the roll ;) .
Here's an example: Linky
:cheers:
I guess it all does go back to ying and yang. Usually what I hear just before a big flop is "don't worry your planted".
I love my cruisers but from what I have read lifting them 6" is a bad idea due to the sheer waight of the body.
WTF? Where exactly have you "read" this? Post some links, quote someone, something.
I've heard Action Jacksons is very unstable and he goes through rear axle shafts like crazy with 40's. Well at least that's what they said.
Again, who is "they"? Sean drives his truck with his kids in it so I don't think he'd be too keen on it being "very unstable". And last I knew he had the one single incident where you had the same issue Christo and NW-Sickboy with the axle splines spinning in the rear diff when locked with the factory e-locker and it not being able to be pulled out requiring the axle housing to be cut open.
And from a first hand perspective I drive my truck daily on 37's with 8.5" of lift (Slee 6" spring, 1.5" spacers & 1" body lift) and I get in and out of other trucks, cars, vans, etc all the time as a consultant and I am always pretty happy about how it rides. For all of its capability it is still pretty quiet, comfortable and handles both on and off road just like it is supposed to.
Mike,
I believe some folks over on Pirate have told him this... If he is the same one over there asking about running 39's on an 80??????
-Matt
