FJ 40 Bleeding brakes
West Linn. Oregon
Soooo been on forum before months ago with question on bleeding brakes on '70 FJ40. Replaced new master cylinder and still couldn't get consistent fluid flow to rear wheels. Bought a HF air compressor vacuum bleeder. Got mostly bubbles at left rear drum cylinder bleed valve. Went to first fitting downstream from master on firewall/frame. Got good bubble free fluid. Then went back to right rear drum bleeder valve and mostly bubbles. Then went to T fitting on rear axle, put plug in on left side and took tube fitting out on right drum cylinder and put vacuum directly on flare fitting and got bubble free fluid. Then went to brake pedal and pumped through bubble free fluid. Put flare fitting back on to back of drum cylinder tried vacuum at drum cylinder bleeder valve, got mostly bubbles. Even though new cylinders, assume pulling air around seal inside. So then tried pumping brake pedal and have no back pressure just soft pumps and rear cylinders don't activate. Don't find any fluid leaks anywhere else under frame.??? Nothing leaking from rear wheel cylinders.
Should new drum cylinders leak air that much?
Oh yea using teflon tape on fitting threads trying to seal threads.
Brake lines don't seal on the threads like tapered pipe threads; They either seal with a flared tube or fitting matching a seat (left on illustration below, ignore the right illustration).
I imagine the teflon will not seal brake threads, since they likely prevent the fitting from sealing the tube on the seat.
images
or a copper gasket where one end of a brake hose threads into a fitting (gasket part no. 33 below)
images
If I read it correctly, you took it apart at tee connection on top of the rear axle, plugged the drivers side rear and pulled a vacuum from where it connects at the passenger rear? I've never read a recommendation to do it that way, unless you were just needing to check if the line was plugged I suppose?
When I dug into it a lot of folks recommend the old fashioned brake pumping technique for these vehicles. I have a cheap vacuum bleeder and that didn't work for me either. Having my helper pump the pedal worked. It's also recommended to just start with the furthest bleeder, driver's rear, and work counterclockwise to the driver's front, and only bleeding through the bleeder valves (not disconnecting any hoses or hard lines during the process).
It's also necessary to have all 4 drums (all 8 cylinders) adjusted tight, to where the wheel won't spin, and then backing off 1-2 clicks. If you can't hear the drums dragging slightly when you spin each wheel by hand they're too loose. Some folks have bad luck with air getting trapped in aftermarket cylinders too.
Based on your test I’d say you have leaking (air) connection based on what 73fj40 posted above. And it looks like you narrowed it down to the remaining right-side connections in your test. So could be bad tube/flair or bad banjo fitting. Maybe @Rainman can add some additional expertise in flare/fitting leak testing.
Also bleeder could be leaking, not sure how those seal when opened for bleeding - would have to be via threads somehow.
Wrt possible leaking in/from cylinder, have you physically moved the suspect cylinder up and down (carefully and just a little) to see if the seal(s) will seat?
Plugging driver's side was an attempt to isolate right or left. Maybe not conventional but hey I'm reaching here.
Tried traditional pumping method off and on for last six months replacing parts as I went. unfortunitey the bad master got me off track. Recent pumping just yields more bubbles in fluid.
Didn't know about adjusting drums tight. Will do that next.
Thanks
Just plugged right side because I couldn't get flare fitting out of left side drum cylinder.
Haven't specifically tried cyliners up or down. Will try that.
Always use new copper o's if that is what it came with. I use the Phoenix Systems bleeder. It pushes the fluid up to the master. Bubbles want to go up, not down.
Got in a Sunbeam Tiger where a complete brake job was required with new everything. The only way we could get the new wheel cylinders to quit leaking where the line was screwed in was Teflon tape and torque. I use the tape all the time.
I guess my summation is, just because the parts are new, doesn't mean they were machined correctly. So sealing may be a problem.
Also check the flared ends for spurs on the brake lines. And sometimes it takes a long time to figure it out.
I've done brake jobs where I couldn't get a firm pedal to save my life, and then for some unearthly reason after going back thru the entire system........BAM......nice solid pedal and no explanation.
