FJ 2F carb q,s
73 original 2 f has not been started in 15 yrs. What can be removed from carb without effecting running,evaporated. Emission control device etc. is the line to fuel pump the only one required?,
Gas tank gone.......any other advice would be helpful,
Thanks.
Yes, single fuel line to the carb for that year. If you upgrade to a different fuel pump (newer) you have a return you have to deal with. I stayed with the single line. I would drain the oil, pull the distributor, pull the plugs and pour in miricle oil, fill it with new oil and manually prime the engine before I even thought of starting it. As everyone will say, welcome to Mud and Welcome to the madness. Post up some pictures as well. There are plenty of threads in the FAQ section etc... on desmogging. I would also tap and plug the galley plug per many others advice as well and if you have them remove the air rail and add plugs. jimc sells them. There are tons of other things to consider as well, but that is a short list to begin.
