Fixing the drooping rear wiper
Oregon
My rear wiper was floppy and droopy. It worked, but it sat low at rest and clunked in use. The linkage had fallen off the bushing where it meets the wiper arm. The linkage was rotating against the stud rather than riding on the bushing which, in turns, rides on the ball. The linkage fell off because the shoulder on the bushing had worn down (the one on the right):
i.php
After wasting entirely too much time looking for replacement bushings, I went down to Ace Hardware to see what I could find. I found some Heim/Rose/ball joints in 1/4-28 (fine threaded). They only had 1/4-20 (standard thread) All-Thread, so I had to get creative. I got a couple of 1/4-28 screws and welded them to some small-diameter tubing I had laying around:
To connect the new linkage to the wiper and motor arms, I had to get the existing balls off. I found that the easiest way was to grind off the mushroomed side and drill out the center. One popped out while drilling, and the other knocked out easily after the drilled hole relieved pressure. The part that goes through the arm is smaller diameter than the stud that the ball is on, so you can't push it through the other way.
When I went to mount it the new linkage, I discovered a problem. The ball joint shaft and locking nut were big enough that they collided with the center nut of the motor arm. This prevented the linkage from laying flat, so it couldn't be mounted to the wiper end. In the process of fiddling with it, I broke my terrible welds.
So, I re-welded the linkage (with better penetration this time), added a slight Z-bend, and used several washers to space the motor-side ball joint away from the motor arm:
The linkage nut still taps on the motor arm nut, but it's very minor interference. It will probably need attention in another 20 years or so.
Total cost: $9.29 each for the joints, plus around $2.00 in nuts, bolts, and washers, plus a random section of tubing, plus ~$500 in welding equipment. :)
What I would do differently
If I were doing this over, I would use male Heim/Rose/ball joints, preferably with extra long shafts. This would allow for zero interference. Unfortunately, Ace was out of male joints, so I had to work with what I had. This whole thing might be a bad idea, since now the linkage may be strong enough that, if the wiper arm were caught on something, it might end up breaking something else. I'll take my chances, though.
Great way to make the fix. Ingenuity!
my wiper is pretty solid, it's just that about 1/3 of the rubber actually makes contact with the glass
That makes it about as useful as my rear defroster
Mine isn't too great, either. I put on a Bosch wiper and the, roughly, 2 o'clock to 4 o'clock outer third makes poor contact. I think a different wiper blade would fix that problem.
The problem i have living in Arizona, due to the lack of rain fall, intense heat, and sunshine the dam rubber blades rot away before you even get a chance to use them. Because of that I've never once turned on my rear wiper, i don't know if it even works.
