Sorry in advance for the wall of text!
1996 Land Cruiser, 305k miles, recently had to drive through almost 5 feet of water to get the family to safety after tropical storm Imelda dropped a ton of rain on our area. And not just once, not even twice. It went through several miles of deep water. After getting us around through the flooded roads the next couple days it was parked and has been since the 23rd of last month. I checked the diffs, engine, and transmission fluid afterwards and all were good. Only thing I noticed was that the diff lock light would slowly come on as I'm driving down the road. And by slowly, I mean it would start out barely illuminated and work its way up to full brightness. If I went to low range and back to high it would go away for a while.
Last night I drove it to meet a friend at a restaurant, we were there an hour or so. Went to leave and everything was good. At the first light I get to I hear a low squealing noise, and it goes away when I get moving. It shifts through first fine, then to second fine as well, but I notice it's hanging in second gear longer than it should have. I let off and pull in to a parking lot to check things out. Nothing looks out of the ordinary, I check underneath, I check the the trans fluid again, all good. Go to leave, put it in drive to leave and it just revs up like I didn't even move the shifter. I go back to park, then to drive, nothing again. I go through all the gears multiple times seeing if there is anything different between them, nada. Go to low range, nada, back to high, nada. It's just like as if I didn't even shift it out of park. I check to make sure the arm on the transmission is moving as I go through the gears and it is. I leave it since it's now 3:30 in the morning and I'm beat.
Go back today to see if maybe it was just a weird one time thing, and sure enough it moves fine, for a little bit. About 50 feet away is the road, I pull out and the trans starts slipping so I let off the gas and coast to a stop and get it towed home. Everything still checks out fine, fluid is nice and clean, doesn't smell burnt, lever is moving on the side of the transmission, yet it doesn't move.
I'm stumped, and nothing is coming up on the search either. Anyone have any ideas on where I should start with this?
