I have the f/c solenoid on order. Lol I think so does
@Rigster ?
There must be a pandemic! Lol. Okay. Maybe too soon for those jokes. Maybe 2024?
22390-56291 - Solenoid Assy, Fuel Cut, Toyota. New spare parts Toyota from Japan with easy payment system and door-to-door delivery.
www.megazip.net
That's what I have coming. Keep testing methodically and you'll get it!
Did yours fail???
I do have an update…. But I’m not proud of it.
I disconnected my solenoid, still blew a fuse. At this point I’ve disconnected every major component that is related to that fuse (including the gauge cluster).
I inspect the junction, all the plugs and wires, nothing. Everything looks fine. I go back and look at a post from 2014 of an hzj77 with the SAME ISSUE, only his died while driving
. In the end he put a 30a fuse in there, it didn’t pop, and eventually he put a 15 back in and it worked. The suggestion was to use and amp clamp to find what wire is pulling more.
So I figure, ok I’m not going to damage one of my precious 24v components, let’s just put a 20a fuse in so I can keep the circuit alive long enough to check some wires.
Key on, hear a small fizzle from the RH kick panel then it stops. Smell a little cooked smell. Turn the key off, put a 15a in, no fiz, no pop of fuse, everything is on. Wtf. I’m thinking great, it just “self cleared” it’s contact with ground.
So I remove the fuse panel and pull out all the wires and connectors I can in that kick panel to inspect and look for SOME sign of short to ground.
Nothing.
I can’t find anything, it all looks fine, nothing rubbing through, no exposed wire, burn marks, anything. Went for a drive and tried every electrical function in the truck (didn’t take long lol) and everything is working fine? Even all the items on that fuse circuit.
So I have a bunch more fuses in my Doug’s tub now, and I may make a little stub connector to add to my solenoid as a back up for the future. The guy from 2014 hasn’t had any issues since, but I’m not stoked to have and NTF upon inspection when I know there was som short happening.
I know….shade tree mechanic status achieved.
