Bodean Hot Damn Joined Dec 20, 2004 Threads 618 Messages 11,684 Location Brandon, MS Oct 27, 2017 #21 Fillup4 said: Thanks, @MScruiser @wngrog @Bodean. One OEM mechanical fuel pump and carb assembly in route from @cityracer. I'm going to hit up @pmccraney for an air cleaner assembly. Install will be a learning experience ... Click to expand... Well all you have to do is yell for help with this bunch and you'll have a few to help and heckle in no time!
77TLCFJ40 10 Year 15 Year 20 Year Joined Jul 30, 2003 Threads 176 Messages 5,866 Location Madison, MS Oct 27, 2017 #22 Fillup4 said: I've decided she is bad luck. Click to expand... That's the spirit!
F Fillup4 Joined Jun 19, 2017 Threads 1 Messages 15 Location Mississippi Nov 1, 2017 Thread starter #23 My first order arrived from cityracer. Still waiting on the carb. Hopefully, I'll get this installed this weekend. But first,
F Fillup4 Joined Jun 19, 2017 Threads 1 Messages 15 Location Mississippi Nov 6, 2017 Thread starter #24 ... and, I have no idea what to do with this. The good new is I've got it.
wngrog Supporting Vendor SILVER Star 10 Year 15 Year 20 Year OG Joined Feb 10, 2002 Threads 624 Messages 49,685 Location Canton, Mississippi Nov 6, 2017 #25 You need a gasket for the base and a wire stop for the choke Cable. The air cleaner rod comes over from the old carburetor. It’s a direct bolt up. Run the vacuum line from your distributor to the base of the carb near your valve cover.
MScruiser obsessive-compulsive oppositional-defiant wise-ass 10 Year Joined Jan 3, 2012 Threads 93 Messages 6,243 Location Jackson, MS Nov 6, 2017 #26 I need a few of those base gaskets myself. Anyone know the part number or where to find them?
wngrog Supporting Vendor SILVER Star 10 Year 15 Year 20 Year OG Joined Feb 10, 2002 Threads 624 Messages 49,685 Location Canton, Mississippi Nov 6, 2017 #27 I bought a sheet of Ramflex material and made the last two I've needed. Used a .35 brass for the stud holes.
F Fillup4 Joined Jun 19, 2017 Threads 1 Messages 15 Location Mississippi Nov 7, 2017 Thread starter #28 How about a hard fuel line? Where might one locate such a fine item. I'd like to ditch the hose(s) ...
wngrog Supporting Vendor SILVER Star 10 Year 15 Year 20 Year OG Joined Feb 10, 2002 Threads 624 Messages 49,685 Location Canton, Mississippi Nov 7, 2017 #29 I’ve got a return hose with banjo fitting on one end and a metric flare tool. Does your current have a screw on fitting at the carb? You could reuse it.
