firing order "F" engine
st augustine fla
My 66 FJ-40 with a F engine runs good after tune up and carb cleaning but noticed that the distrubitor cap firing order is 1,5,3,6,2,4. mine is wired 5,3,6,2,4,1 in the cap numbers 1,5,3,6,2,4, timing light will not show the timing mark. put vacmum guage and it show the engine is running with no problems. :confused: what is correct for a F engine?
Stock timing set up is 153624. Sounds like a PO had the timing so far off, they switched the wires around instead of fixing the timing.
Good luck!
Fuggedabout the cap numbers.
Someone put the dizzy in off a tooth or two and the easy way to compensate is to move the wires over by 1 on the cap. Just hook the timing light up to trigger off the #1 plug wire that is the closest to the radiator.
no big deal... if you want you could pull the dizzy and move it ccw one tooth but i would not mess with it. If you do make sure that you get the dizzy fully seated in the oil pump. Once i get the dizzy in i grab the remote start and crank it over a few times while i push down on the top of the dizzy. This ensures that it is fully seated before starting the motor up. The results of a non-properly installed dizzy are a motor re-build. This is why i would run the truck until you are sure that you want to change it. The motor dose not know the difference.
It may have been done purposely so that the oil filter didn't interfere with the old style vacuum advance distributor from the F engine. By moving it by one spot, the diaphragm is pointing at about 2 o'clock intead at 12. In fact, I had a tech at SOR recommend that as a solution.
