Fine spline third member
Knee deep in hookers and gin
Forgive my ignorance, but I'm looking at a 83 FJ-60 front axle to swap into my 74 40. I'd like to gain the disc brakes, added width and fine spine axles and birfs. The gearing is, of course, the problem. I know I can swap in a 62 third, but why can't I just swap the ring and pinion gears? Did they change the carrier more than just the spline count?
If my info is correct, all third members up to 1990 will interchange. The only diferences will be driveshaft flanges, and those can be changed also. Check back issues of trails, Rob Mullen had two article on gear boxes in cruisers. I think it was 1998.
I would imagine the R&P can be changed, but you'll have to set backlash etc...
ring and pinions will swap.
Which splines are you referring to? The Birfield has coarse splines on the '74, as does the '74 pinion. You can swap the R&P from the '74 third to the '83 third, but then you would give up the stronger fine spline pinion and thus the swap would be pointless. The best possible swap would be an FJ62 front axle which would get you all the goodies at once-fine spline pinion, 4.11 gears, and of course the later model and fine spline birf, and you would only need a different pinion flange. If you can find a '78 third member it will have the 4.11 fine spline pinion and the correct flange bolt pattern. The carrier and the case are identical '69-90, but on the FJ62 the case has some extra finning I think. Also consider the rear R&P from an 80 series-it will work on the older thirds but the carrier/case will not work without modification on the older axle.
My '84 FJ60 has '78 3rd members, so I did sort of the reverse of what you are proposing.
My '76 FJ40 has knuckle/spindles/birfs/hubs/brakes from an '83 FJ60, and fine spline R&P from Precision Gear. I love the mix and match aspect of the older cruisers.
If you use the '83 axle, it might be easier, but a bit more expensive to order a new R&P and just rebuild the diff and be done with it. I was looking at Cruiseroutfitters site awhile back and Kurt had excellent prices on a brand new R&P. I am assuming as a professor of automotive knowledge you can set up your own differential and thus save the set up $$.
Forgive my ignorance y'all, but I just have to ask about the whole "fine spline" thing...
My rig is a '78 40, with a 09/77 build date. So I hear I should have fine spline something.
When I replaced the rear pinion seal, the picture below is what I had - looks coarse spline to me!
Can someone educate me as to what I should have fine and what should be coarse?
TIA,
I think that the break to fine spline came in January '78. Before that - course spines, no matter what the year model is. I have a '77 model with a 9/77 date, BTW, so they must have designated the year model sometime during that month.
Sorry no pic of fine spline pinion - the difference is very obvious though, I just swapped out my '76 R&Ps and there is no need to count splines to differentiate between the two - coarse is coarse
Your birfs should be the same as mine - fine spline but odd size, smaller bell and longer shaft -
Not sure the intro year for fine spline axles, yours are for sure though -
Update - more information
I have some new information, but some of it conflicts...
I was looking through some old Toyota Trails, and found an article on transmissions, t-cases, R&P ratios, and pinion flanges. It was written by Rob Mullen.
This article is in the March/April 2000 issue of Toyota Trails.
There is a table on page 55 that shows the flanges. It says that Toyota kept the same dimensions for the flange when they went from coarse to fine, but that they went to fine spline in July of 1978.
This is contrary to what honk was saying about the change over being in January of 1978. Kurt (Cruiseroutfitter) lists flanges on his website, and he says the switch was 01/78 as well.
So who is right? Rob Mullen? Kurt and honk?
If they did switch in 07/78, that would be a short run of fine spline, 4.11 R&P diffs if they started the 1979 model year as early as Sept of 1978 build dates...
Anyone?
Some deep trivia here! I have '78 differentials on my FJ60 and they are fine spline. I have no idea of the build date. I too had heard the change was early in the '78 model year, but I'm also sure the factory would use up all the coarse spline stuff they had left, and so in 9/77 when the model switch over was you probably got the last of the coarse spline 4.11s.
You cannot always tell what you are going to get by build date.
There were too many variables....
PabloCruise said:
Honk,
Very cool on eyour build date.
Anyone have a pic of a fine spline pinion?
Are all the axles fine spline?
What about my birfs?
TIA,
here's a pic of a fine spline pinion. axles were course spline in the early til mid 60's years. your birfs should be fine spline, but the longer version that was 76-78
