Finally took off the drop brackets
Germantown, MD
Slee plates showed up at the door on Friday. Got to work on Friday night. Man those bolts from drop brackets were *&^%# @itch, bent due to 3+ years of bashing. I had to take of the arms with the brackets on then basically improvise. Breaker bar + my 350 ft lb torque wrench and wife's 4Runner front tire as leverage. The bolts were gunked up. one can of WD40 plus the orage stuff I got didn't do nothing. It took me most part of SAT. to budge the nuts on those brackets. Finally gave up and picked the up grinder and cut off the bolts. Finished it all up the today.
I gotta tell ya, steering is mush tighter, right of the bat my steering play is gone! The brackets are really good wheel stopper :D. I guess I have found new use for'em now.
:cheers:
:cheers:
Too mush holiday cheer?:D
:cheers:
Did you have the 3" or 4" drop brackets on?
:cheers:
Ahh, the gorrilla method...near and dear to my heart :D
I just pulled my 4" brackets and picked up some plates from Slee; drives better, even though the axle had to get pulled back about 1".
never ran brakets .. but definately love my caster plated .. how much lift you have to get the axle back 1" with the caster plates .. ?
I have slightly over 5" lift. I did one side at a time to notice the approx. 1" shift in the housing. I finally had to pull the other side loose and ratchet-stap the axle back. I also noticed less of the bump stop centered in the coil now. I guess nothing works as well as the replacement arms, just couldn't afford laying down $1080 incl. tax for them.
ya I see much more noticeable with big lift .. I'm not planing ( not yet :) ) go over 3" ..
