Finally on the road again!!! (brakes)
NorCal
After a month of pulling my hair out, buying and returning parts, wrenching at the junkyard and in my driveway, I'm finally on the road.
I ended up with a brake booster out of a '91 4 runner, which is a little wide and barely fits between the clutch master cylinder and the hard brake lines on the other side.
My biggest problem, and I've never seen it mentioned before, was the little bolt on the side of the master cylinder. I poached this pic from the 'net:
During my bench bleeding, I backed the little bolt out. That allows the front piston to pop out too far, and when I screwed the little bolt back in, the front piston could no longer move in the cylinder. Of course I didn't notice. That made me think the boosters I was experimenting with didn't have enough throw.
At the PMC swap meet (awesome day, BTW), I talked to some guy who convinced me it probably wasn't a booster issue, I put it back together. I checked the booster throw with no MC, and it went to the floor, but with the MC bolted on, it only went half way.
I took my old MC all the way apart to figure out what was wrong. When I popped out the little bolt, I heard the cylinder pop out. I screwed the bolt back in and tested the travel, and sure enough, it would only push in about 3/4", instead of over 1.25".
You have to push the cylinder part way in before you screw in the little bolt. So I went back to the cruiser, backed off the bolt, had my 8yo push the pedal down, retightened, et voila, it works like a charm.
Finally I put in the last two new wheel cylinders, bled that circuit, and it is, in the immortal words of Willie Nelson, on the road again.
Of course, now the nagging question is whether you 'dented' the piston in the MC by tightening it down in the wrong place the first time.
The 'world' wants to know!;p
Good meeting you Saturday.:)
Good to meet you too!
Yea, nagging is right. You had to bring it up, didn't you. :o
The brakes work well and I'm pretty tired of working on them. I would think that if the piston was dented, it wouldn't hold pressure? I'll play with my old one a bit to see what happens to the piston when you tighten the bolt with the piston in the way. IIRC, there is rubber as well as metal. Maybe it just pins the cylinder against the opposite wall?
You could've just let me go on thinking I was done...
Oh,
