Fickle starter......
Alabama
Most of the time it starts right up and it doesn't sound like it's struggling (going bad) at all. Then it won't crank. When this happens, I hear the relay engaging. I can see a slight load moving the voltage gage. But I usually have to keep turning the key on and off till it starts.
It's a 1994 model and any advice would be greatly appreciated!
Your starter is telling you its time to think about the next phase of its life. Beat on it with whatever you have handy when it doesn’t want to start. This is the equivalent of using the shock paddles during cardiac arrest. It’ll work for a while, but the end is near. In the meantime, order a replacement.
Almost always the contacts in the solenoid worn, can replace them or the whole starter. Best to fix the problem ASAP, in this condition they can stick, causing the starter to continue running with the motor. If this happens, it over speeds the starter, have come apart, causing a dead short to the battery, fire.
Mine was sticking on last summer, had to whack it with something to get it to disengage, not a lot of fun! Rebuilt with OEM parts (plunger and contact kits) and it's good as new again.
