Few questions (winter paranoia)
Eicca
Professional Noob
Utah
Ok, so I'm being really sensitive to anything out of place with my truck right now, and I've got a few things I want to check on.
First, when it's idling, it's nice and smooth, but occasionally I'll feel a jolt and slight shaking. I read somewhere this may be a misfire in one of the cylinders. What should I look for?
Second, my voltage seems weak when idling. The needle will drop almost to the middle, and moves up and down with the blinker(s) on. Also, with the brights on, blinkers going, and all four window swithces pulled up (and the Christmas lights on) the needle dropped below middle and the tachometer was twitching in time with the blinkers. Brand new OEM alternator and brand new Costco battery. Should I be worried?
Third (but least important), I'm smelling coolant in the heater. Already ruled out the heater core as I don't smell it when it's on recirculate. Coolant level is still good.
Thanks for putting up with my paranoia :) :beer:
Check for a vacuum leak somewhere first (loose hose, cracked intake, etc). I would clean everything up, new spark plugs, clean up the intake, etc. Replace your spark plug wires if they are old, they could be arcing.
Does it only do it when it's cold, or does it do it when it's warm as well?
What size battery? Could be undersized.
Sounds like the exact symptoms I had with a bad battery, but could be a lot of things include wiring.
You mean you turn on the heat and you smell coolant in cab?
If it's only happening when it's on fresh (and not recirc), then it has to be coming from outside the vehicle.
Every 80 I've been around smells like coolant to me, though usually it's coming out of the exhaust.
Replacing the plugs and wire is on the list of things to do.
Looking for a vacuum leak, where's the best place to start? What hoses and components might be at fault?
The jolts happen both cold and warm.
Does amp output tell battery size? It says on the battery itself "640 cold cranking amps, 800 amps max"
Most common one is the intake. When people clean/change their air filter they twist/bend the intake hose and crack it, usually where the ribbing is. It gets brittle with age so it's easy to do.
If I remember right the stock battery size is group 24....Sears Diehard is only 585 cca. So I would think that 640 CCA should be fine (unless you have a parasitic drain which is draining your battery and killed it).
That being said, the battery I'm using is 1150 CCA. (Sears PM-1) :grinpimp:
You can have the battery tested, and battery place and most auto places should do it for free. I would definately have it tested, and follow the other FSM tests.
I've attached the On Vehicle Inspection guide for the charging system. Run through that and see if any of it fails. An FJ-80 will be different than an FZJ-80, but it should give you a rough idea (and some will be the same).
Thanks for the info. Do you know how much those intake hoses usually cost?
Contact CruiserDan. They're around $80 + shipping. Local dealer here wanted $150 for it.
Fixed the low voltage and stumbling issues. New plugs and wire. My truck even SOUNDS better now! It's so cool!
