Fender question
Val-David
HI! I'd like to change my rusted fender on my 1971 FJ-40. Maybe I have a deal on some nice 1978. Is this a ''bolt on'' job ?
Thanks :beer:
pretty easy.
The aftermarket ones fit all years, so I am guessing the factory ones will as well.
The aftermarket fenders needed some bolt hole enlarging, but not too bad for my 67.
On a 71 there is no emissions. The turn signal hole would probably be the only difference... but it should be a fairly straight bolt on application.
bolt on-depends on how many old rusty bolts you break
I just put a 78 fender on my 74. The turn signal hole is the same even though the bracket under the turn signal hole is different. The 78 used plastic wire holders not the coated steel bend overs on the 71. Other than that the fender was a bolt on.
Thanks for all your reply :beer:
