Fender Mounting ?
Ohio
Gents,
I recently destroyed a Ford Escape on my way to Deer Camp. While the Escape sat in the ditch never to run again, the 80 sat triumphantly on the road way.
The Escape was able to smash my front right fender. I picked up a fender for it at a scary Detroit scrap yard.
I haven't tore it apart yet and after searching the oem sites and my FSM, I can't find a pic of what is behind the fender for mounting.
Can anyone tell me if there are any brackets etc. Behind the fender that I may need.
Thanks !
Outer fender is bolted at bottom to tub/cab, back by door on a tab, at top under winshield wiper valance, then to inner fender, then up front to the core support.
You will need an entire inner fender. Front core support may be tweaked, but you should be able to straighten it.
f521f4bf-c267-4216-9c76-3da272b20d2b-jpeg.1552605
Guess you may have crushed the air inlet box too. That is the only thing back in that space. If you did, you can get a replacement... or you can pop on a snorkel.
Agree wth 2F. Grab an inner fender too. Bolt up and tweark core support to match. Even the winglets behind lights are individually available.
Thats the easy side to swap ;)
Easy swap..... nothing special to look for, and like others have said- the majority of the “metal” (more like tin) is extremely light weight, so it’s a piece of cake to massage back into shape! Good luck!
Replacement corner lights can be found on amazon and Ebay cheap. You’ll also need the little retainer for it. Also check to make sure the headlight mounts didn’t crack.
