Fender liner splash shield
Camuy, Puerto Rico
I always wanted a FJ40 and finally found a rust free although highly modified cruiser down here in Puerto Rico. The older gentleman I purchased it from moved the gas tank to the rear under the floor. When you look up in the right aft wheel well, the piping is exposed and I was wondering if there's any kind of after market liner or an ideal to protect the tank and lines.
Sounds like you need a skid plate of some kind.
I take it the gas tank is behind the rear axle under the rear deck with the filler pipe running from the stock location?
Not knowing exactly how it was done makes it hard to make suggestion.
I have seen clamp on heat shields for exhausts. Maybe you could incorporate something like that.
I had an eleven gallon aux. tank in the back of my FJ40 and made a second filler behind the right rear fender well. The pipe was metal so I didn't worry about damage.
On a 1970 ish 40 there were splash guards for emissions equipment if your trying to cover the filler neck. It’s up behind the rear wheel and keeps stuff off the rear sill as well.
