Fender engine splash cover thingamajig.
Gilbert, AZ
Does anyone know where I can find a replacement engine splash guard for a reasonable price? It's the rubber cover that's attaches to the fender with plastic clips? I need the front driver side for a 2017 Tacoma. My dumb self forgot to reattach all of the clips and it went flying into highway land.
You can make your own on the cheap with shower pan liner from a local home improvement store. Cut to fit, works great, and won't break the bank.
What section of Home Depot would I be able to find this? I also need the clips since I lost those to the highway.
In my local Home Depot it is near the shower doors, inserts, etc... Back of the store. It is usually on a big roll... Cut and buy what you need. I have a medium gray color.
Please holler when you have this installed...or let me know if you want to meet up for two-brains-is-better-than-one time at Depot. I'm more towards central PHX, but have several instances of wheel well fixing needs.
I'm all the way in Gilbert so I will probably go to the Home Depot just down the road from me. I'll make sure to document the process and post it up when I get it done.
I have heavy duty rubber you are welcome to very close to the same factory material.
Hey Phil, I'm more than happy to use your rubber, when are you available? I won't be able to make this month meeting since I will be out of town.
I can just leave it out for you to pick up at your convenience. Let me know how large of a piece you need.
Pro-Tip: insert a bolt into each of your mounting holes and when you hold the rubber piece in place, whack the rubber with a hammer on each of the bolt heads without moving the rubber. This will imprint the locations of the holes on the backside where you can now drill holes for your mounting plugs to go.
You can’t go wrong with radrubber.com for these.
Hi Phil, the size that I need is 11" x 15".
I was thinking of removing the passenger side and use it to trace it over the new piece and then cut it.
