feel the vibrations
Oklahoma City, Oklahoma
ok so i finished the lift on the cruiser and im feeling vibrations from the back. they occur approximately mid way to the top of third gear . the vibrations increase in severity at the very top of third gear then when i shift to fourth immediatly stop. im stumped on this one because im very confidant that my drive shaft andgle is sufficient and that its straight......my mechanic mention a third gear bearing in the trasmission and im hoping thats not the case.....id rather it just be the driveshaft.......it ran well before i lifted it! see what ya think, all inqueries appreciated
mine does that but I just let it roll. 3 years now and had extra driveline built waiting for this thing to lose it, has not happened . I figure the stock splines in the slip cause it as mine has persisted thru a tranny rebuild and a new t-case , new springs , bushings and third member , so I guess they just eggbeat a little , I plan on getting custom cv shaft from drive line solutions to solve.
BTW The other stock driveline I had lengthened and new Toyota u-joints put in did the
same thing , even worse at certain speeds .
Did you have the driveline off at anytime while installing the lift? If so your driveline may have been put back on out of phase. Just my .02
I had a problem similar to this after I had my drive shft out to change the tranny. to fix it I pulled the 4 nuts off of the parking break housing that hold the drive shaft flipped the drive shaft and bolted it back in. it drove nice and smoothafter that I think that is what you call in or out of phase.
yeah i never removed the driveshaft throughout the lift process and all i did was basically put bigger leaf springs on lengthen the brake lines and restore the driveshaft angle to its previous position with the 4 degree shim......i am still using the stock driveshaft.....any recommendations on how to get the shaft back into phase?
hmmm....well im positive the shim is installed correctly, and it doesn't appear to be overkill as the shaft and differential housing are linear.
u joints have no play in them
