I have a 74 Fj40 (12/74) that needs a new carb. I see that there is a Fed carb and a California carb -- I do not need to pass smog or anything - Is there a difference in the two (ERG - whatever that might be)? SOR did not know the answer. They have CA in stock.
The tag on my hood has been painted over indicating ca / fed. There is no tag on top of my carb that I can see. The vehicle ID tag inside the door does not indicate fed / ca.
If I bolt a Ca carb on a Fed FJ (in case mine is a Fed) does it cause problems?
What carb - if you had to put a new one on -- would you use?
Thanks
Thanks
