i know the flood pattern is used as a fog lamp,
I don't think the floods will be great as fog lamps. Maybe a spot pattern mounted under the bumper. The flood is going to reflect off the fog.
so like a smoked glass spray?
Not sure if there's transparent yellow glass paint or there, but A plastic lens or an adhesive backed yellow vinyl (like 3m) should work.
I don't think you did this yet... Can we see a pic of the TrekPod Mono XT (flood)? I'm thinking of adding and wanna be sure what I need. Thanks!!
-Daniel Kent
-Daniel Kent
I Promised pictures a week ago but ended up with a water problem in the house. I've been a little delayed.
To review I purchased:
- 7.5 inch light bar
- 8 degree pod
- 40 degree pod
This is how it they look against my low beams. I chose low beams as it would show the difference. In all photo's my low beams were on in addition to a single Trek light.
low beams (camera's automatic focus had trouble with the low light conditions) (no focus problems when the lights were turned on)
7.5 inch light bar
Narrow Pod
Wide Pod (camera didn't capture the spread very well but the image was brighter still)
Output is very good especially when combined with my regular lights.
Cheers John
Tommy, www.Lamin-X.com is one vendor you could check out for this sort of thing. It's what they specialize in. Of course, eBay or other vendors will have alternative products.
thanx, ill look into this more when i get the lights, seems pretty pricy for just wanting a small piece, also I'll have to make sure the product is transparent, and heat resistant
Thank you For the repost! How far out do you think those floods go? I need a wide spread up close, but I need it to shoot out I'd say at least 20' too. Thanks!
-Daniel Kent
Into the sky. Notice how there's enough spread to shine a bright light onto the trees, while throwing a killer spot beam into the sky:
Ok... I'm gonna change up my order a bit, so here's what it should look like.
(1) 22" TrekLight ES Spot (Hardened Glass)
(9) TrekPod Mono XT (Hardened Glass) - 7 Flood / 2 Spot w/8 deg Flood
Ok that's it, I'm cutting myself off!
-Daniel Kent
Im in for:
(1) 18" TrekLight XT: Spot pattern
(1) Treklight Mono XT: Flood pattern
PMing you my email address
