Favorite Oil to Use?
shawn said:
am i the only fan of royal purple 10 W 30 out here?
Yup, from what I remember in past oil discussions, Royal Purple ranked at the bottom of the synthetic oils, along with the old castrol. It seemed like a pretty bad value anyway, as it was quite a bit more expensive than other synth, but it's been a while since I looked at how much it costs.
slick621 said:
Ok thanks! I thought i saw a Mobil 1 mineral based at WalMart the other day but must have been another brand.
Mobil makes a mineral oil, comes in a blue bottle labeled "Mobil".
"Mobil 1", however, is strictly synthetic.
I usw Amsoil mostly because it's easier for me to buy locally (I can buy at their warehouse directly) and is therefore cheaper than paying retail for Mobil 1 (which I used to use). The other reason is that I could buy all the other synthetic stuff I needed (eg both types of grease, gear lube, ATF) at the same place.
Cheers, Hugh
What do you folks think of Valvoline MaxLife (mineral)?
I change every 3000-4000 miles, and my truck doesn't seem to eat much at all.
Also, I take it there are also some strong opinions on filter brands. I've been using Fram P8H. I suspect that some will recommend something different. Why? Please elaborate.
While we're giving opinions on various slippery fluids, why don't we list them all, and why?
Hayes uses:
Motor oil: Valvoline MaxLife (mineral) because the name "MaxLife" gives me warm fuzzies.
Oil Filter: Fram P8HA because the guy at Checker told me to use that one.
Tranny: Valvoline MaxLife DextronIII same reason as motor oil.
Gear Lube: Valvoline 90w because I've apparantly got a thing for Valvoline.
Did I miss anything?
Hayes
Good day 80 people! Have a FJ60 with 138k....Use it in 20W-50, it made a huge change in engine noise. K&N filter here.
Hayes
LMAO. That is the same Filter that fram has made for 30+ years. It was originally speced for Ford small block motors (260/289/302/351w). Fram filters are about as worthless as they get, paper drainback preventers, little filter media, etc.. As others have suggested, Factory, Wix, Napa Gold, are all good filters.
Cruiserheads,
If you have a Camping World in your town, check to see if they have Mobile
One oil on Sale. I just purchased 16 bottles for 3.29 a bottle. That is all they had. I am going to check online too.
Grouseman
Grouseman said:
Cruiserheads,
Grouseman
You were ripped off. Mobil 1 is the good stuff, Mobile 1 is some company trying to capitalize on the hard work of Mobil. :D :D :D
Crank Case: Shell Rotella T 15w-40 (summer)
Mobil 1 5w-30 (winter)
Both of these are 3K intervals
Transmission: Coastal ATF (I switch it out every 3K)
X-fer-Case: Coastal 80w-90 (changed out every 3K)
Differentials: Coastal 80w-90 (changed out every 3K)
Brake Fluid: Valvoline Synthetic
Power Steering: Mobil 1 ATF
Radiator: Toyota Red (changed out once a year)
Motor-Mobil 1 15w-50, trialing 0w-40 right now, 5k intervals
Diffs-Chevron Delo Gear ESI 80w-90-yearly change, or after deep water
Transfer Mobil 1 75w-90, yearly change
ATF-Mobil 1 Dexron III, 4 qt swap at each oil change
Wheel bearings-Mobil 1 grease
Knuckle and all zerk fittings-Amsoil Moly Grease
