Fast idle screw
Bay Area California
Which one is my fast idle screw...after some work I turned the car on and vrooom - fricken jet engine .. need to lower it...
cant tell which one it is...left or right.. in regards to my picture?
Thinking it’s the left ... other one is choke adjuster
Whoa nelly, there is so much wrong in that one little pic!
First, the AP pushrod is on the wrong side of the throttle arm. It is binding against the side of the fast-idle screw.
Second, the hi-idle throttle lever & link is OOP. Disconnect the idle up link, then move the lever to the left in pic, then the link will drop down, right next to the spring bracket.
Once that is done, let us know how it goes.
I guess I shouldn’t have been so confident when I whipped it off and put it back on ... after rebuilding once .. totally screwed the pooch
that answers my question of why it was steaming when I turned it on lol
Do I have to take off the fast idle arm there and literally flip it around !? Why the **** was it even switched . Jesus ... because if I just take off linkage and bend it back it’s till not oriented correctly according to picture ...
can I get confirm on that?
Don’t wanna mess this up ... answered my own questions. But still looking for extra guidance on the order / orientation of these ... last time they were put together incorrect ... have FSM and Haynes .. looking through now for this specifically
I don’t have a link handy, but SOR has pictures on their website of every carb model, taken on all four sides. You should be able to match your exact carb and figure out your linkage from that.
Just think of it as the picture you forgot to take. ;)
I’ll check it out thanks for reference
Think I got it but I must be missing something - a washer or some spacer because in the 2 pics with my needle 👃 pliers In there are showing the space to one side then pushed over showing space on other side ... showing range of motion ... maybe normal .. doing some digging...
