Im a search tard. Can someone point out a link to set timing on a 91' 3fe 80 ? and other handy tips
thx
thx
Have you done timing before? I know nothing about the 3FE although I diod a lot of work on a 2F.
Timing light clip on Spark plug 1
Power cables on battery
Find the timing mark (on the 2F it is on the left side just above the starter)
May need to clean off timing mark.
Check timing, light blinking on mark tells you where the timing is, mark show up in one spot either to left, right or right on mark.
Need to find out what the timing should be.
Loosen distributor, do not pull out as it drives the oil pump, turn distributor slightly to the left or right to get desired timing.
Oh yea ive timed lots. I have a nice gun. I guess what I really could and should have asked is where the heck is the mark on the 3fe ? I dont see a mark on the harmonic ballancer or what I call the timing cover.
So on the 2f is the distributor on the left as well. Otherwise how would you reach the distributor and read the marks.
Cover to the flex plate ? or somewhere on the front of the motor ?on the 3fe there is a rubber plug that you pull out of the cover to see the timing mark
