Fan hitting shroud
Texas
when I'm driving it sounds like the fan hits the shroud randomly, and when I turn to the right. The shroud is tight what could be the issue?
Motor mounts and/or transmission mount are your likely culprits. Give the radiator a good wiggle, too, to see if the isolators have deteriorated and are allowing the rad and shroud to move. For the fan to hit the shroud, one of two things is happening: the motor/fan is moving or the radiator is moving. Given the age of all these trucks, those motor mounts are probably pretty tired at this point.
And the bottom sides of the shroud that both are in place, or rather in the retainer thingies.
