Fan Clutch
TEXAS !!!
Had a new indy do some work on my rig. Among other things, he says the fan clutch isn´t working. With the truck fairly cold, you can grab hold of the fan and stop it while the motor is running. I seem to recall discussion about the clutch engaging at fairly high temps and am wondering if this is a good test on this rig. My dashboard temp guage always reads dead middle and I have never had a problem with overheating.
Is this test he used of grabbing the fan a valid one for this truck´s fan clutch ??? Especially when it is relatively cool outside???
It's a good test if the motor is up to operating temp, the thermostat is open, etc, you shouldn't be able to stop the fan. Most of the time the clutch is good, only the fluid dies, so if it's replaced, like new or better performance is restored, depending on the viscosity of the fluid.
There is a very long thread on this forum about it, or a more condensed version on the mini forum;
https://forum.ih8mud.com/79-95-toyota-truck-tech/167678-fan-clutch-service.html
One thing to note is the stock temp gauge has a 30-40 degree dead zone. By the time you see it moving beyond dead center, your truck is overheating.
So what happens if you can't stop the fan with your hands? Not a good way to test anything...trying to stop a mechanical device with your hands. I suspect its really going to hurt if the fan does not stop.
The general way to test the fan clutch is to get the truck up to operating temp.....turn engine off and see how hard fan is to turn with engine off by hand with engine warm. Fan should have some resistence when turning. (test works better in summer).
I would never trying to stop the fan clutch from turning by hand with the engine running. Those fans can really do some damage.
Get truck up to operating temp....turn on the A/C and go out and give it hell for a few miles....stop and turn engine off and do the test. Of course in the summer you normally hear the fan clutch engage with ambiant temps around 90F or more.
Yes, with it cold, he took a towl and pressed it up against the fan and could stop he fan.
