I have a black Aisin. I'm upping the fluid from 10k to 12 to help when I tow.
Anyways, while draining I checked to see when it opened. I don't have access to a stove to do it with water so I used a heat gun and it thermometer.
It was opening around 215-220. I adjusted it very slightly and it opens around 110-120.
Has anybody else used the heat gun method? Are my temps ok or do I need to set back to factory? Before when it finally kicked in while towing it was too late and I was at over 215* water temp (vdo gauge on the dash).
Thanks for the help fellas
Will
Will
