Fan Clutch 3FE
the water pump and the fan clutch are two seperate parts, no water in the fan clutch.
The fan should be on at start up and at stop lights even this time of the year on the 3fe.
You will know it when its on , it takes alot of power from the engine and its loud. If its not running hot in the summer time its probley working fine.
U can check for play in the bearing by grabing the fan blades with yr hand ( WHEN THE ENGINE IF OFF! )
Keep in mind you must do this when the engine is fully warmed up thus locking the fluid coupling.
Turn it off and try to spin the fan to check for resistance. If you can spin it more than 1/4-1/2 turn it is bad (in my experience)
Water pump? If you aren't leaking on the ground more than likely it is fine.
Thanks for your answer guys.I was in stop in go traffic on the interstate one day and the gauge moved up to 3/4 but not in the red. Also it was 90 plus degrees out. I went about 2 miles in one hour,with ac running.
Replace it with OEM and move on.
x2 - Make sure you do not buy an aftermarket fan clutch. They are usually smaller in size - they fit but they don't lock up as solidily and move much less air. Mark Whatley wrote this up in Toyota Trails a while back and I found out the hard way as well.
