Mine did the same thing (brake+battery light) also sometimes heard a bussing sound from the pass side kick panel area. Replaced Alt. problem solved.
On to my next repair..
On my 1988 FJ62 the red BRAKE and the red Battery lights come at the same time. When I'm driving and and acclerating these two lights go out, but as soon as I slow down they both start to flicker and then stay on. Has anyone else experienced this issue? I'm asking becuase before I start to tear in to the dash or instrument cluster I would like to minimize any damage from digging in to deep.
Thank you.
Don't feel bad...I paid about $1100 to have a significant exhaust manifold repair done on my 04 Sprinter van...they had the engine out at the time and I couldn't think of anything else to do while they had it out. About 100 miles later the CPS failed...is stuck in the block, and I pretty much have to pull the transmission at this point to drive the old sensor out....a lot of aggravation for a $25 partYea, the sad thing is I had the entire front end of this engine off last year when I replaced the water pump and radiator. If I only knew then.....
I'm going to start looking at prices for alternators today.
So where is the relay?Well, I replaced a loose and worn out positive battery terminal and I still have the chattering relay along with the Battery and BRAKE lights. I cleaned and reseated the negative lead connection too. When the truck is sitting at idle the voltage across my battery measures at 14.4 volts. It seems like my alternator is fine unless it is not putting enough amperage out along with voltage (overall wattage generated?).
I checked with Toyota and the relay from them would cost $131 (jeeze, that’s a lot for little plastic relay!).
I guess before I replace this really I could inspect my fusible links a little closer, but visually I'm not seeing anything right now.
I had the same problem with battery and brake lights coming on at low speed. It was the alternator. Had it changed two weeks ago and problem solved.
then yesterday both the brake and battery light came on and have stayed on no matter what. Any ideas? Maybe that relay mentioned above? Where is it? I already replaced fusible links last year.
where the relay is to replace for this issue?Well, I replaced a loose and worn out positive battery terminal and I still have the chattering relay along with the Battery and BRAKE lights. I cleaned and reseated the negative lead connection too. When the truck is sitting at idle the voltage across my battery measures at 14.4 volts. It seems like my alternator is fine unless it is not putting enough amperage out along with voltage (overall wattage generated?).
Did you ever figure out where this relay is?Can you tell em
Alternator, both my '88 pickup and '89 Cruiser behave that way
Edit: I just read the title more better and realized this thread is about a FALSE indication. Mine definitely wasn't false...
I had this issue last week with the charge and e-break lights on on my 86 FJ60 driving Sonoran roads at night, pulled into a Toyota factory mechanic at 1030pm and had some of the best factory techs in the world take a look (I'm totally serious, it's a long story but best in the world, not shade tree mechanics). After chasing down every wire in the engine compartment (and lots of comments on my home wiring), the confirmed I had no wiring issues. They pulled the brushes out of my alternator, cleaned them up, cleaned up the contacts on the rotor, problem fixed. 5am the next morning I was back on the race course with no charging issues. Toyota's head mechanic told me that was probably only good for a week or two, but that was good enough to finish up the race and get back to the US. I learned it's not too hard to pull the brushes and inspect them, even with the ALT still installed.
Clark
well, don't hold out on us, show us how that brush r+r is done with the ALT still installedEdit: I just read the title more better and realized this thread is about a FALSE indication. Mine definitely wasn't false...
Clark
also, that long story, we've got timeI was down in Mexico for the W2RC Sonora Rally as one of the Tango's (medical support trucks) and my alternator gave up the ghost on a long haul between Hermosillo and Puerto Penasco. Obviously no mechanic was open at that hour, and neither was any auto parts store. After stuffing my face with the last of dinner that was being served, someone mentioned there was a Toyota racing team and maybe they could help me out. I strolled over there beer in hand (hey, it was 2230 and we had all started at 0430...I needed that damn beer!) and the pit crew were just finishing up their maintenance of the "Hilux" they were racing. I put "Hilux" in quotes as it doesn't look or sound much like Hilux besides the grill, but they sure were cool to watch go by. Anyway, I explained I was the driver of one of only three medical trucks, my alternator wasn't working, and I was really hoping to be back out on the course at 0430 again the next morning. I'm sure I looked as scruffy as I felt after 18hrs, but they agreed someone could take a quick look if I pulled it up in front of their booth. Soon as I pulled up I got the whole damn pit crew descended, not just the low man on the totem pole that I expected.well, don't hold out on us, show us how that brush r+r is done with the ALT still installedalso, that long story, we've got time
thanks man. n you've never washed that shirt, have ya?I was down in Mexico for the W2RC Sonora Rally as one of the Tango's (medical support trucks) and my alternator gave up the ghost on a long haul between Hermosillo and Puerto Penasco. Obviously no mechanic was open at that hour, and neither was any auto parts store. After stuffing my face with the last of dinner that was being served, someone mentioned there was a Toyota racing team and maybe they could help me out. I strolled over there beer in hand (hey, it was 2230 and we had all started at 0430...I needed that damn beer!) and the pit crew were just finishing up their maintenance of the "Hilux" they were racing. I put "Hilux" in quotes as it doesn't look or sound much like Hilux besides the grill, but they sure were cool to watch go by. Anyway, I explained I was the driver of one of only three medical trucks, my alternator wasn't working, and I was really hoping to be back out on the course at 0430 again the next morning. I'm sure I looked as scruffy as I felt after 18hrs, but they agreed someone could take a quick look if I pulled it up in front of their booth. Soon as I pulled up I got the whole damn pit crew descended, not just the low man on the totem pole that I expected.
It took them maybe 20min, but they chased a bunch of wires, questioned me about almost everything non-factory, and determined it was the alternator and most likely the brushes. One of the mechanics pulled the rear cover off the alternator, removed two more screws and out came the brushes from the rear. They confirmed that yes, those were severely worn out, discussed getting the brushes for the Hilux to fit. That that would require machining and they didn't want to start up that trailer at this hour, so ultimately it was decided to just clean everything up real well and off I went. Alternator made it the remaining four days of the race and back home to central AZ.
You have to keep in mind, this was my first ever time attending any rally race, no less a part of the "Road to Dakar," and I've never been into such things before and so was totally un-aware of who these guys were. Learned the next day this was Nasser Al-Attiyah's pit crew, current world champion.
Pit crew working things out...
Worn brushes...
Back of the alternator, you can just see the brushes inside the center there, with two screws to remove and that whole plastic unit comes off with the brushes inside. Though I drive an FJ60, this is a 62 alternator.
Clark
P.S. The next morning I got Nassar and his arch rival, 9 time world champion Sebastian Loeb, to sign my crew shirt.
