Falling on face
visalia ca
I have a 1968 Fj40. We put a 1984 fj60 2f motor into it. Had a Rochester 2 barrel on it and that took a dump. Put a rebuilt marlin Toyota carb on it, replaced the fuel line and also the filter.
Starts great, idles awesome. 1st-2nd gear runs great. 3rd gear hesitates and 4th gear falls flat on face. Runs out of gas. Pull over sight glass shows empty. Let it sit 30sec and starts right up no problem and starts all over.
Need help.
Looking for a pvc valve also can’t find the one in the picture below.
If your carb bowl is empty odd are there's something in your tank plugging the pick up tube, or the needle valve in your carb is sticking.
Is fuel pump pumping plenty of fuel?
I picked up a PCV Valve from $OR about a year ago. You may be able to resurrect that one with some kerosene, assuming the spring is still good in it. But easier to get a new one for around $18.
