- Joined
- May 19, 2005
- Threads
- 73
- Messages
- 693
I'll check the sensor and save it if I can. But I think it was pretty badly mangled from the PO. He must have burnt out a cat cause the sensor (that was already just hanging out under the frame) looked melted.
If that sensor is burnt and for some reason is telling the AI system that the cat is overheating then you'll be stuck in bypass mode.
Most of these hoses are as hard a rocks from being under the hood for 20yrs. so they'll be bitch to take off for testing. I had to order one short one ahead of time and cut the old one off when I was doing my final testing. Use a little KY jelly on the ends of the new hose if you get one it will make the reassembly really easy.
As I mentioned before, take off the bypass hose from the air cleaner and make sure there isn't any air flow comming from it...if there is you are in bypass mode and you'll have to troubleshoot from there.
The system will push air into the mainfold below 45 mph and then down to the cat above 45 mph, but either way you shouldnt have any air comming from that bypass hose sitting at idle
Get the manual out and start to get familiar w/the AI in general.
Pg 3-20 will show you a good layout of how things work.
Good luck, Bryan
