Failed Smog pre-test and something else weird
Today my 96 1FZFE with over 200,000miles failed the smog pre-test (CA of course). the tech said that HC is 130 and I'm only allowed 100 max :crybaby: so he suggested that I probably need a tune up or worst my rear cats have gone bad. What you guys think?
Here's the weird part of my trip to the smog station. I noticed that he only had the rear tires on the rollers spinning for about 30 seconds so I stopped him I told the guy that it has full time 4 wheel drive and he said Oh! OK! so he change the test procedure. Off the rollers, what's weird to me why is my front tires not trying to spin/roll at the same time(as the rears)? is this right? is my 4wheel drive(fulltime?) broke? or is it just I don't understand how the system works.
I know too many questions all at once, but I would greatly appreciate If somebody here can help me understand if I'm missing something on what I saw, :confused: or maybe it's really broke.
Strange, it should have rolled right off the rollers. I wonder if your VC is shot.
Concerning your smog, if you haven't done a tune up recently, it is a good place to start. Before doing the tuneup, run a bottle of redline fuel injection cleaner through your truck.
When you get the smog done, make sure the Cats are fully warmed up. To do this, drive on the freeway for 10 minutes or so before you get is smogged. When you pull into the smog place make sure they are ready for you. Keep the engine running and get it on the smog machine as quick as possible. Cats work best when hot, even sitting an idling will allow them to drop to lower than their optimal operating temp.
If that doesn't work, then it is time to start looking at a new cat.
You're right Cary. I just ordered some stuff(wires,sparkplugs, filters etc) for tune-up, just to eliminate any possibility by taking care of the easy(cheaper) parts. I will try your suggestion on keeping the cats nice and hot prior to testing.
I forgot to mention that I actually failed the HC on the idle test, could that mean the cat. I read somewhere that the purpose of the secondary or rear cat is to take care of stuffs like HC. Not really sure but I hope the cat is still good if not I might have to find a good(cheap) source to replace it. (CA is too picky:o)
Really strange!! :confused:I don't know if the VC is shot? I guess I have to do some more research. I figured I'd share my experience here so that people with similar experience can chime in. Is there a practical test procedure to verify why the 4wd system is doing this? I'm thingking about putting it up on a lift to see how they roll. I don't know just throwing ideas untill I find a practical/reliable way to test the 4wd system.
FT4WD80S
'96FZJ80
If your failing during the idle part of the test from high HCs then check your EGR valve to make sure the seat isn't leaking. Sometimes the seat will let unburned gases through and spike the HCs.
Being OBD11 it should throw a check engine light at you if the Cats are not performing to standard. High HC's means it is running a bit rich so tune up stuff is a good start. Is your check engine light working properly? My buddy just told me the smog guy ran his Cruiser on the dyno. Luckily that was a '91 non VC. You VC is probably fine.
GA doesn't dyno OBDII trucks anymore....they run the diags on the computer and call it a day...good luck...i wonder if the dyno was making the drivetrain struggle with the VC, etc and caused a rich mixture? You aren't far off from passing so I would be suspect....tune up first if you haven't done it...worth it anyway.
were the front wheels choked?
why on the dyno? I never had to put mine on the dyno in CA. Depends on location?
The guy screwed up. Full time 4wd trucks never go on the Dyno, even in Smog II areas. To the best of my knowledge, there are no 4 wheel smog dyno.
Fellow sufferer of the PRK.
